Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navisworks or 3D Max?
17 REPLIES 17
Message 1 of 18
6052 Views, 17 Replies
Hello Everyone,
In terms of animation which of Navisworks or 3D Max is better. Can you please put down some reasons?
Thanks.
17 REPLIES 17
Message 2 of 18
lee.mullin
It depends on what you want to do. Navisworks tends to be used mostly for creating simple quick animations, such as demonstrating a construction sequence. Whereas 3DS Max would be used for more complex animations and rendering.
You can get great results in both, this for example is a construction sequence in Navisworks
This is a great article about creating smooth animations you may find useful.
http://beyonddesign.typepad.com/posts/2011/06/creating-smooth-animations.html
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
Message 3 of 18
Patrick_Aps_9121
To make it simple:
if the technical contents is more important than the good looks of the animation,
   If you need to measure, see if something fits, see if everything is accessable....
   and end-users do not bother what color the walls have, as long as they are on the right location...
   if you want to deliver a file where end-users can roam around freely...
   and where custumers need to command and give feedback on the model
use NavisWorks
if the look and feel of the animation is more important than technical correctness,
  if your end product should be an filme and nothing else
  if the materials used must have the exact look in the animiation
use Max.
Message 4 of 18
Hopefully this is the right place to ask this question.
If you have a Navisworks file is there anyway to import into 3D Studio Max.
I am asking for another person, so if specifics are needed I can check with him.
Thank you
Rick
Message 5 of 18
DarrenP
you can export out of navisworks to .fbx file and import that file into 3ds max
depends on the version of navisworks
DarrenP
Message 6 of 18
in reply to: DarrenP
I have Navisworks Freedom 2012 and want to open .nwd file in 3D Max. Please guide me how can i export .fbx for 3D Max. I am not familiar with Navisworks and could not find any export option in it :(.
Thanks in advance.
Abdul
Message 7 of 18
lee.mullin
Hi Abdul,
Navisworks Freedom does not allow export of models, only viewing of NWD and DWF files.
You will need Navisworks Simulate or Navisworks Manage 2012 to be able to export to FBX. More information can be found here
Lee Mullin
Autodesk Ltd.
Tags (3)
Message 8 of 18
alatriste15
in reply to: lee.mullin
I have only used timeline simulation feature to make a export movie. but recently i have seen your animated construction autodesk movie on youtube. it is amazing. I liked the animation which you had used in your movie. as an intermediate naisworks manage user, I would like to know how to use this animation tools in your video. so far I have only used timeline simulate in order to create an movie. I am not familiar the animation part in navisworks manage 2012.
I would be grateful to you if you could provide any tutorial or actual movie for your animated construction video on youtube.
I  desperately need your those kinds animation technics for my building construction project.
thanks
Message 9 of 18
in reply to: alatriste15
Same Question from my side too. I was amazed to see that youtuube video. Any help will be highly appreciated.
Thank you.
Message 10 of 18
The construction sequencing is amazing - I would like to see it export to 3DS max in order to achieve higher resolution, greenscreening, and photorealism.  The rendering time in Navisworks is painfully long, and doesn't allow for render farm usage either.
We are doing a minute-long sequence in Navisworks and it is taking almost a full week to render.  Our client is seeing it as a waste of time as the animation quality is so poor.
Message 11 of 18
DarrenP
maybe in a future release of navisworks that would be pretty cool
DarrenP
Message 12 of 18
dgorsman
If you are doing a minute-long animation as a single unedited sequence, yes it will take some time - longer without extreme hardware.  Typically what is done is the images are rendered in either short segments or single frames, then editing software is used to stitch them together coherently (after post-processing).
Long "beauty shots" aren't that common in the media industry.  Have a look at animated and FX-heavy movies and television shows, and watch the editing.  You will see the majority of times between edits are in the 3-5 second range, and thats with professional video editing, specially created hardware and software, and huge budgets.  Looking at the original construction sequence carefully you can see where the sequences could be broken down into more manageable chunks.
For a full-on high end render in 3DS Max you will likely be better off taking the original data and opening it with 3DS Max, rather than translating to Navisworks, then translating to FBX (or other supported format).
Message 13 of 18
Yes I agree - it would look amazing to see on a real site.
Message 14 of 18
in reply to: dgorsman
As I understand it - Primavera provides the data that Navisworks uses in the Timeliner.  Can it be imported somehow into Max.
Message 15 of 18
dgorsman
Dunno... you would need to ask a "3DSMax professional" for that one.  They may get their animation and camera controls from other sources.
Message 16 of 18
lee.mullin
At the moment you would need to 'fake' the construcion sequence in Max, there's no way to export that or the animation from Navisworks or link to Primavera through Max.
Lee Mullin
Autodesk Ltd.
Message 17 of 18
Thanks Lee,
This would be a great feature to add to Max in the future!
Message 18 of 18
hello friends
I have a serious problem in the export of native RVM file AVEVA PDMS to Autodesk FBX file.
Since my idea is to transport the AVEVA PDMS model to Autodesk 3dmax to create a stage environment with animation and real material thing with AVEVA Review can not be done, much less with the Autodesk naviswork
I draw the pdms rvm and then I export to Autodesk naviswork because there is no direct export to 3dmax
The naviswork it works to perfection right there and do the export to FBX but when you export to 3dsmax FBX through a freeze on the model, it is impossible to work in
My pc has the following characteristics
intel core 2 quad q8800
8 gb ram ddr2 800 mhz
1 gb ddr3 video card
I would like to know if anyone has had the same problem as it is too time than it takes to load the FBX in 3dmax
You try everything I canceled during the export lights, cameras, and textures, I've also updated the FBX plug-ins to the most current but I still have the same problem
Hopefully they can help me solve my problem thanks and regards
Rail Community
