Navisworks Model to VR (Oculus Quest 2)
Owackenreuther
Message 1 of 8
Owackenreuther
I'm wondering if I can export a Naviswork Model to Virtual Reality, specifically to Oculus Quest 2. I'm hoping to retain the attribute data and access it in Oculus. Is this possible? If so, what would be the steps to achieve this?
Replies (7)
Message 2 of 8
jrobrador19
Hi there,
Have you seen this link?
https://blog.irisvr.com/navisworks-vr-walkthrough
I have no experience yet in using Prospect by IrisVR with Navisworks, but in the link, there is a detailed way of converting your Navisworks model to VR. Towards the end, there is a feature which is Inspect Element which allows you to view the attributes of the elements in the model.
I hope this helps.
Please hit the ACCEPT SOLUTION or LIKE button if my post helped you to solve your problem.
Jerous Obrador
Mechanical Engineer| LinkedIn | Autodesk Certified InstructorRevit Architecture Certified ProfessionalRevit MEP: Mechanical Certified ProfessionalRevit MEP: Electrical Certified ProfessionalInventor Certified Professional | Laguna, Philippines
Win 10 Pro / Dell G7 7590 / i7-9750H / 16GB RAM / NVIDIA GeForce RTX 2060
Message 3 of 8
Hi @Owackenreuther,
Not sure if you found what you are looking for. Checkout https://www.exxar.cloud/cad-to-vr/.
Exxar converts native Navisworks models to a multi-user VR experience without any data loss, without manual data conversions. Complete part hierarchy and metadata are retained during the conversion process. Exxar's Huddle client is available on the Quest 2 as well as other VR/AR devices.
Have fun...
Message 4 of 8
mgundersonQ6BWH
Community Visitor
Community Visitor
HI THERE, I WAS JUST WONDERING IF YOU WERE ABLE TO GET IT TO WORK, AND IF SO, HOW YOU DID IT?
Message 5 of 8
Owackenreuther
@mgundersonQ6BWH, yes I did get it to work with @jrobrador19 recommendation.
However, if I were you, I would hold off as I suspect that VR functionality will be available soon in Navisworks Manage.
Message 6 of 8
eblackburnTDSKF
2 1/2 years later... it's still not there and probably won't be now that Autodesk has their cloud-based extra-subscription-required XR workflow. They need to rename it "AEC Partial Collection"
Message 7 of 8
Owackenreuther
I should of seen that on the road map. New and exciting features = Autodesk Construction Cloud functionality only. I understand that all software can go to the cloud, and it may sooner or later through the evolutionary process. I'm not a fan of adding one niche feature to the cloud while the Desktop software, in this case Nacisworks, is still required. Autodesk should transition the entire software to the cloud instead of parts here and there. It makes their offering much more confusing to use and explain to stakeholders.
Message 8 of 8
eblackburnTDSKF
I would be ok with Autodesk charging a little bit more for a complete AEC Collection with full cloud access instead of 2 separate revenue streams. It would vastly simply development as all users would be on the same model with the same features. That's my thought, anyway...
