When I go to measure with the measure tool in Revit. It does not show the distance? It just says that all measurements are 0.00
Any help would be great! Thank you! I have looked and the options and everything is correct there.
Solved by !Dalton_Goodwin!. Go to Solution.
Hello Ronald,
I am using Navis 2016. After closing the model and then re-opening it, it started working correctly. Just for curiosity is have you seen this before? I think it is just a little bug that can be fixed by restarting that software. Thanks for the help.
