Navisworks Manage 2019 clipping box issue
I'm having a issue when using clipping box over point cloud data in Navisworks Manage 2019, more precisely my point cloud data is not cut exactly by clipping box edges some points still visible outside it. Please check pictures. I want to mention that I have this problem only on my workstation equipped with AMD GPU, the other one with Nvidia GPU is working well . Any advice how to fix this?
Point cloud data not get a clear section by clipping box on AMD GPUPoint cloud data not get a clear section by clipping box on AMD GPU      Clear cut by clipping box on Nvidia GPU.Clear cut by clipping box on Nvidia GPU.
Replies (7)
My system configuration:
  • Laptop Asus GL702Z
  • GPU AMD RX 580, CPU AMD Ryzen 7 1700
  • Operating System Windows 10 64bit
  • Driver version installed: Radeon Software Adrenalin Edition 18.5.1
  • RAM 32 GB
  • OS installed on SSD Samsung EVO 970 512GB
eric.zhang305
Autodesk Support
Autodesk Support
Hello @Anonymous, try this setting.
  1. Update to the latest video driver here.
  2. Right-click the desktop and choose "Configure Switchable Graphics." If this is not available, try choosing "Catalyst Control Panel" and then click the "Power" tab on the left and then "Switchable Graphics."
  3. If Navisworks is in the list, select the "High Performance" option for it. If it is not in the list, use the Browse button to manually select the Autodesk Navisworks file.
  4. Click Apply.
Let me know if this works for you.
Dear Eric
I have the latest video driver installed, and my laptop have only 1 GPU so "Switchable Graphics" option is not available.
eric.zhang305
Autodesk Support
Autodesk Support
Thank you for the information. Can you check if your Hardware Acceleration for Navisworks is checked?
  • In Navisworks
  • Click the Logo on the top left
  • options
  • Interface
  • Click Display
  • Graphics System
  • Check Hardware Acceleration
eric.zhang305
Autodesk Support
Autodesk Support
I am checking back to see if my post helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Yes with hardware acceleration enabled i have this issue. Without hardware acceleration clipping box is working ok, but any pan / zoom is very very slow due to heavy point cloud size and working like that is impossible.
eric.zhang305
Autodesk Support
Autodesk Support
Does your computer allow you to right click and go into your graphics card settings? Can you see if this option is similar to what you can try?
