Hi
I have an assembly in Inventor 2013 with quite a few content center parts, all this parts are not showing in my Navisworks 2013 file.
I read a topic about setup a Navis project, but I cant find nothing in Navis 2013 to setup a project.
Any help will be super appreciated .
Regards
Luis Mestre
If I remember well, there is something in Inventor to "freeze" the assembly
after that, you also may need to change an option in Navisworks
Options -> File Readers -> Inventor
fill in the complete path\folder\project.ipj with the filename and ipj extention included.
then try to append it again.
you may also want to check what the "load the assembly with the last active representation" setting has as effect.
Hi Patrick
I did all your steps apart from the "freezing"assembly . I cant recall anything to "freeze" an assembly, are you referring to make a derived part ?I still cant load content center parts in NAvis, have a look in the attached files.
Thank you very much for your help.
Luis MEstre
