I am exporting large navisworks geometry to FBX for use in Rhino and 3DS Max. The imported files have different issues, but in each case I believe it is related to the extreme distance of the output geometry from the origin. The help documentation suggests I need to remove the geographic coordinate system, but I can't find how to do that.
The project is urgent so I am in grave need of help. I have attached a sample section of the overall document.
In Rhino, all the trees end up at the origin, along with several hundred other objects, while much of the other geometry is out of place. In 3DMax the geometry is distorted and jagged, as if coordinates have been rounded.
Thanks in advance for any help.
