Navisworks Export Revit without closing the NWF file
Engr_Rod_D_Lecetivo_RMEE
Hi all,
Here is the scenario.
I have an NWF files wherein I linked all the NWC files I have exported from Revit.
What I want.
I want to export NWC file in revit while my NWC file is linked and in use with NWF file in Navisworks.
When I finish export to update the NWF file. What I need to do is to reload.
I very much appreciate your reply in this.
Best regards,
Rod Domagsang Lecetivo
brett_parkerLUEP7
Hello
Thank you for posting to the forums.
What you are describing sounds like the 'Refresh' functionality in Navisworks. Help files can be found here
This allows you to re-export linked files and refresh inside Navisworks for the update.
Regards
Brett Parker
Navisworks Product Manager
chester.daliwan
just check this one and hit OK
then close the navis and open again model...
load your updated NWC to the folder and replace the old one.
Hit the REFRESH in navis work.
hope this works
hmunsell
if i understand correctly... when your NWF is open, you want any NWC crated/updated while you have the NWF open to auto update in the NWF.
Howard Munsell
