I just want to selected viewpoint to be exported. How to do it?
I do not want like previous answer safe the nwf format, deleted unwanted viewpoints, unsafe nwf file - it is tedious to me.
Sorry, but there is no other way.
See also:
How to export single \ selected Viewpoints from Navisworks
Selected Saved Viewpoints Report Export
If my reply was helpful, please "Like" or click the "Accept as Solution" button below (or both).
See also:
Have you found any good solution to this issue over the previously mentioned workaround? This is something i find could be very useful and should be implemented in a future release. If you haven't found a solution and have proposed this as a future idea let me know where you posted it so i can like it and help push it into a future update.
Maybe the iFBIM CVPSync Plugin is what you need. You can download it the app store from https://apps.autodesk.com/NAVIS/en/Detail/Index?id=2925403578903343399&appLang=en&os=Win64
It syncs all or selected viewpoints and/or clashes with their web portal where you can manage them.
you can check out the web portal by registering at https://ifbim.ifieldsmart.com/#/
