Announcements
NAVISWORK FIND condition not listing Wildcard option for some properties
Abbas_AliQQJ6N
Observer
Abbas_AliQQJ6N
Observer
Observer
Hi
In Navisworks FIND an Item, can't see WILDCARD condition for some properties. Understand that might be related to type of property but how can we use wildcard property for a property if not listed and is a string type property coming from Aveva E3D
DidierRamirezDarjo
Hello, I hope you are feeling well. I do not know how is the data structure used by Aveva E3D, however, I recommend that you first locate in your model imported to Navisworks where is the Parameter you are looking for, as you will see that the data structure of Navisworks, search in all hierarchies of the models and in the different tabs of the hierarchies. Once you locate this, you will be able to configure your search rule more accurately:
I hope you find it useful, greetings!
Abbas_AliQQJ6N
Observer
Observer
Hi Didier
Sorry not sure what exactly you mean. Can you please elaborate  ?
Abbas_AliQQJ6N
Observer
Observer
Found the fix.
If data input to Navis with quotes, wildcard appears
:CHECKED:=  'false'
