Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Naviswork Coordination Add-In for BIM360
1 REPLY 1
jfahimXN9KY
222 Views, 1 Reply
I have Navisworks Freedom 2024 Application installed, and running, on my desktop. I have some files in BIM 360 that I wanted to open and view on Navisworks instead of BIM 360. I saw online that I can do that by downloading/installing the "Navisworks® Coordination Issues Add-In" which I downloaded and installed. However, even after restarting my device, I do not see the coordination plugin or tab showing on Navisworks. I know it was downloaded and installed properly ( I can see it on my control panel). Am I missing something? Is there a better method to open BIM 360 files on Navisworks? (other than using the cloud method). Thank you.
Labels (3)
1 REPLY 1
DarrenP
in reply to: jfahimXN9KY
It doesn’t work with freedom
Pulled from here: https://apps.autodesk.com/NAVIS/en/Detail/HelpDoc?appId=5155805354033590972&appLang=en&os=Win64#inun...
From website:
Installation/Uninstallation
The installer that ran when you downloaded this app/plug-in from Autodesk App Store has already installed the app/plug-in. You may need to restart Autodesk Product to activate the plug-in. To uninstall this plug-in, you can run the installer again, or click Control Panel > Programs > Programs and Features (Windows 7/8.1/10/11) or Control Panel > Add or Remove Programs, and uninstall as you would any other application from your system.
Requires:
Navisworks Manage or Simulate: 2024 /2023/2022/2021 - Highly Recommended
Autodesk Desktop Connector or Autodesk Construction Cloud® Connect App (Autodesk AppStore)
Document Management Project Access.
Model Coordination Project Access.
DarrenP
Rail Community
