Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Navis saved viewpoint import to Revit
5 REPLIES 5
2451 Views, 5 Replies
Hello
I kindly ask Your support/help in the following topic:
I would like to export the saved viewpoint from NavisWorks (2019), and than import it to Revit (2019) without using any special program or add-in.
Are there any solution for this?  (Eventually both program belongs to Autodesk... there should be easy solution )
I need this to cooperate with co-designers for easier problem localization.
Thank You!
András
5 REPLIES 5
a_meteni
The switchback functionality in Navisworks gives you an easy solution for that. It simply allows the current viewpoint of the currently loaded file to be sent back to Revit model directly.
in reply to: a_meteni
Thank You
Switchback does not work with collaborated Revit projects on BIM 360 Docs. Are there any other methods for creating views in Revit to match the saved viewpoints in Navisworks?
a_meteni
The Clash Pinpoint feature in BIM360 Glue is pretty much similar to Switchback functionality in Navisworks.
That would work for clashes but it does not work for viewpoints. I am more concerned with sharing viewpoints to Revit in a collaborated BIM 360 Docs model than pin pointing individual clashes.
Rail Community
