Merge multiple IFC files into 1 "combined" IFC file.
daan.kennis
Message 1 of 10
daan.kennis
Hi all,
So i've been trying to figure out a way to combine 6 IFC files i got from subcontractors and merge them into 1 single IFC file.
Reasons why i want to accomplish this is the fact that our colleagues on site can only use Solibri Model Viewer. When i try to combine these IFC files into a new Revit project and try to export only having these IFC files visible in view nothing happens...
I figured to try the same in Navisworks but can't export to IFC there.
Do any of you guys have workarounds or an actual solution to solve this annoying issue? 🙂
Thanks!
Replies (9)
Message 2 of 10
PatrickDavis20
iConstruct (addin for Navisworks) allows you to export IFC files https://iconstruct.com/feature/smart-ifc4-exporter/. I have not personally used that tool in iConstruct to tell you how well it does or does not work.
BIMServer might be an option (I have never tried it) https://wrw.is/how-to-merge-ifc-files-for-free-and-how/
You could also import the IFC files into another authoring app and then re-export, but there would more than likely be some kind of data degradation.
Patrick Davis
Twitter
LinkedIn
Blog
Message 3 of 10
Alan.johnson1970
I can confirm iConstruct allows for IFC export
Although the output IFC file size is very large.
There are multiple options for the output.
I am not aware of any other plugin that can do it.
AJ.
Message 4 of 10
Are you find the solution to combine the IFC?
If you find, can you teach me the way, I have encountered this problem now.
Thank you~
Message 5 of 10
In XbimXplorer you can create federated model and save it to new IFC file.
Message 6 of 10
This clip shows you how you can merge two IFC-files into one "combined" file using the IFC-viewer BIMvision.
I hope you find this to be informative.
https://www.youtube.com/watch?v=xNL3WnPvom4
Kind regards,
Jelle
Message 7 of 10
Se puede exportar a un IFC conjunto posteriormente al combinarlos?
Message 8 of 10
r.waandersEF3FP
You can also use Simlebim https://simplebim.com/  for merging ifc models. And the tool does also great job in cleaning up messy ifc's and has a lot of usefull functions. The program has a full function 30-day trial version. It's really worth it to check out and has an acceptable pricing.
Message 9 of 10
joaquim.danado
That's possible as well using other IFC viewers, such as bimcollab zoom. But It doesn't save the two models into a single IFC file.
Message 10 of 10
Amirhmir
you can use simplebim to combine ifcs into one ifc
Kind regards,
amirh
