Main Problem: Plant 3D properties not transferring on all components within a P3D model to all components within NW file across all computers in a network.
Setup: multiple computers on same network, running P3D 2016 and NW 2016 with OE plugins on all systems. "Primary system" converts file from P3D to NW.
Test: Convert P3D file to NW for review. Converted file registers ALL P3D properties in NW file on primary system, however, when opened on secondary system, P3D properties and P3D property tab disappear for multiple random components throughout NW file model, but not all components.
Test: NW file closed, opened, re-exported and re-saved as multiple formats of NW file and re-opened on primary and secondary computer systems; problem persists. {Primary system (which converted file from P3D to NW) is unaffected as all properties appear on all components within the model. All other computers running same setup still affected.}
Bizarre.
Test: File E-mailed to unconnected system for review: problem persists. Primary system still unaffected.
Problem: Secondary computer systems running same setup (including OE plugins) can not access P3D properties for all components while primary computer can.
*files and data are security sensitive: No examples my be included.
Please advise.
