Hi Chintan,
I think you want to change the hierarchy in Selection Tree.
One way is if you change the Standard selection to Properties on the top of the Selection Tree. This may directly give you many alternatives for seeing your elements.
The other way is you may use Sets and create your own hierarcy of selecting elements by using Search/Selection Sets and create Folders for them.
Hope this helps...
you can see the hierarchy clearly on Properties > Smartplant 3D > System Path from top Dropdown menu of Selection Tree.
