problem 1:
i am trying to attach a dwf/dwfx to autocad mep 2018. i get an invalid file file. Ive exported from both navisworks and design review with the same results. note this is file is a component of a larger layout, for example, a motor in an electrical room.
problem 2: im ultimately looking to import that modeled motor revit file into an autocad drawing , then into navisworks. Once it is in navisworks, it only shows as a block. no details of motor.
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
