Installation issues
Installation issues
Installation issues
hi
haveing probles loading this veiwer on to my computer to be able to carry out some material take offs ,but the same error message keeps coming up had it-support in to try and sort a number of time and not getting anywhere can some one help!! see error list attached
filipefrancisco
Unistall this version, delete all the folders and files of the instalation... Clean your instalation
And them download a new install exe
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
