Announcements
Hyperlinks in PSet-Properties: Navisworks doesn't resolve filepaths correctly
cwr001
cwr001
This topic has come up in some shape or form several times but unfortunately I couldn't find any working solutions so I'll ask again, hoping for some insights:
In Civil3d I've got a 3d-Solid with an attached propertyset and some properties.
One of those properties is an absolute filepath (type: string) that, in this example, references an image:
After exporting, I can open the IFC in Solibri where everything works as expected and the hyperlinks are even clickable:
Opening the same file in BimCollab Zoom, everything works as expected and while not directly clickable, I can open the image with a right-mouse-click -> open.
In Navisworks however, my string isn't escaped correctly and I get a hot mess that looks like this:
I've tried a couple of things, but no matter what, I can't get the string to display correctly:
Not working:
Also not working:
Does someone know what I have to do to make Navisworks recognize filepaths correctly?
I wanted to test @brett_parkerLUEP7 suggestion here that "Properties Panel Enhanced" makes hyperlinks clickable but as shown above, I can't even get Navisworks to display a path to begin with.
Replies (7)
brett_parkerLUEP7
Would you be able to share the file with me directly. This can be done by emailing me privately via brett.parker@autodesk.com
Regards
Brett Parker
Navisworks Product Manager
cwr001
Thank you for your response! This issue is easily reproducible and not just occuring in one file. For reference, I've attached testdrawings for Civil3d 2023 and Civil3d 2024 - it doesn't work with either version.
In Navisworks I'm currently on:
Navisworks Manage 2024 (64-Bit)
Version: 21.0.1397.16
brett_parkerLUEP7
Brett Parker
brett_parkerLUEP7
Having completed further tests, I can see the path now works. If the path is not valid or doesn't exist then it won't become a hyperlink. If the path does exist then the hyperlink should work;
I am not able to recreate the issue where the / is missing. Can you provide a file with this issue present?
Regards
Brett Parker
cwr001
Thank you for looking into this.
That's curious - your hyperlinks seem to get resolved correctly with "\" between folders. When I load the prior attached files, those "\" disappear in (my) Navisworks. Maybe it's a setting somewhere?
I've screencasted my exact steps just to show the whole process - I'm using the files that I've attached in the above post.
- Export 3d-solids from Autocad
- Import into Navisworks (where you can see that the filepaths come in without backslashes)
- Import the same file into Solibri (where it works)
brett_parkerLUEP7
Hmmm, that is unusual. Are you able to uninstall the enhanced properties add-in and reinstall. Latest version can be got from here.
Alternatively, you can check the version via the Windows uninstall apps;
It is also worth deleting all the related files in the directory - E.G NWC, TXT and HTML files
Then reload the original IFC and see if it now resolves the link.
Regards
Brett Parker
cwr001
I've done a whole reinstall of Navisworks, unfortunately, the bug still occurs.
Is there a chance it has to do with language-settings? I'll maybe try installing the english-version later.
