How to edit the first perison view height in Navisworks?
Sleepingfish_Kuo
Message 1 of 8
Sleepingfish_Kuo
Seems the default setting of view height is about 125cm (4 ft).
How to change it to different value?
*add notes: I'm talking about the walk tool with gravity, and add another screen shot.
https://help.autodesk.com/view/NAV/2025/ENU/?guid=GUID-6B7C1C58-FF0F-46AC-A510-87A0B9CDE8DF
Replies (7)
Message 2 of 8
Tomislav.Golubovic
  • Options
  • Interface
  • Viewpoint Defaults
  • Collision Settings
Message 3 of 8
Sleepingfish_Kuo
I tried editing the collision settings, nothing happen in my view.
Message 4 of 8
Sleepingfish_Kuo
I found that I should edit the Collision Settings for current view, not default setting.
The default setting will apply for new views, but not views already built.
By the way, is there a way to set climbing over the funiture with less than xx cm height?
Message 5 of 8
Tomislav.Golubovic
You want to walk through it or not at all?
Message 6 of 8
Sleepingfish_Kuo
Not for this table (with 75cm height), I want to be block just like wall. But still want to auto climb up stairs or some chairs.
I want to know if there is a fix value or can be set by user.
Message 7 of 8
Tomislav.Golubovic
I think you're going to be out of luck there. Unless you model that table with an "invisible wall" the avatar is going to go above it.
Message 8 of 8
Sleepingfish_Kuo
OK, thank you.
