I create animation for object and it run very good but I should manually change viewpoint to other How to Automatic move from viewpoint to other while object animation run …(see attached video) ?
I need to show loading and unloading for object in my project ( pump loading )
Solved by rade_tomovic. Go to Solution.
I suppose you've created this animation using the Animator plugin from Navisworks. In the same manner, you can animate a transition between two viewpoints by adding a camera to your scene in Animator and capturing two (or more) different views. Please refer to the following link
