like described above the Grids and Levels tab is completely greyed out.
Can this be fixed?
Link copied
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Can this be fixed?
Have you got any files open / appended ?
I have tried with appended files and without. in both cases these options are greyed out 😕
The show grid tool is active when a file or files are opened / appended and is greyed out if you just have a new Navisworks file .
Is this Navisworks Manage, Simulate or Freedom?
That doesn´t seem the case here. No matter what i append or do the interface in this section is still greyed out.
Navisworks Manage
Ok after a bit of testing using Revit.
If the Revit file has a Grid then the show grid tool is active.
If the Revit file doesn't have a grid then the show grid tool is greyed out.
Then after little digging and I found this comment posted in 2017
The commands in the view tab are only available when a Revit file is attached that contains a grid.
All other grids (in CAD files, IFC or other applications) are not supported, from version 2014 until current version 2017.
