Announcements
Get BIM 360 Published 3D View Source File Name
tim.ingle
tim.ingle
When trying to create a template .XML file with default Search Sets and Clash Detective settings for a project using 3D Views published to BIM 360 using the Model Coordinate portal, the 3D View's Source File name appears to be a string of letters, numbers, and symbols that does not appear anywhere else from investigation through the BIM 360 environment and Revit parameter properties. Is there a way to find this Source File name outside of Navisworks that can be found and pulled via Dynamo or copied to a text file for use to replace Source File name values in the .XML template?
Replies (0)
