finding multiple objects
Is there a way to search for multiple items at once in Naviworks Freedom.
Hi @Anonymous,
sure there is, you need to go to search and insert the different criteria, or you can create selection sets:
https://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/20...
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
a_meteni
Select & Search panel in Freedom is limited only to Select all / Select same features in addition to the selection tree that may include predefined selection sets published from Manage or Simulate versions of Navisworks.
Unfortunately, Complete search capabilities are not available with Freedom.
tranvanhoe304
Observer
Observer
If you still have not found any way to resolve this problem. Please see the link was attached, here is my channel to share the way to find multiple objects at once in Naviswork by using import auto VBA.
https://youtu.be/F9H2DpSJjw8
Cris_Mabeza
Community Visitor
Community Visitor
I am curious about your excel macro for searching entity in Navis, wanna try it but the google link you provided in the YT video is now broken. Can you update the link so i can check it please? - cheers, Cris
ansarialimbim
I Don't Think This is Possible in Freedom, But we can Find Duplicate Through Navisworks Manage 's Clash Detective Feature.
For Reference See the Image.
Thanks & Regards,
Alim Ansari
