Navisworks Forum
Welcome to Autodesk’s Navisworks Forums. Share your knowledge, ask questions, and explore popular Navisworks topics.
Exporting clash test window to excel?
10 REPLIES 10
Message 1 of 11
TommyNYC
1427 Views, 10 Replies
hi,
is there a way to export my clash tests to excel - so they display exactly as they do in the main clash test window (see attached image)?
I need a concise summary in a simple format - no details of clashes required - just numbers.
so far I can bring everything BUT this into excel.....
thanks
10 REPLIES 10
Message 2 of 11
Nicola_Ianeselli
in reply to: TommyNYC
Hi @TommyNYC,
after you run the test, just follow this:
https://knowledge.autodesk.com/support/navisworks-products/troubleshooting/caas/sfdcarticles/sfdcart...
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
Message 3 of 11
TommyNYC
in reply to: Nicola_Ianeselli
thanks for that
the issue is not getting into excel - its achieving the format in the screen shot once in excel - I may have been unclear.
A concise summary of a complex clash detection process.
I am not sure it can be done.
Message 4 of 11
Nicola_Ianeselli
Hi @TommyNYC,
that's a good point. Surely you can export the classical report and then create another sheet to summarize all the clashes, so as a final result you will get that.
This is a workaround.
I will open it and check it in a sec.
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Message 5 of 11
TommyNYC
that would be possible  - perhaps if it were a one off.
I am looking to summize this report every two weeks and make a graph from it.
so, ideally I want a more direct link.
I cannot believe it cannot be done simply!
Message 6 of 11
Nicola_Ianeselli
Hi @TommyNYC,
it won't take long to create the excel file that will read the reports coming from Navis.
I tried but i think it cannot be done directly.
You are the first user that i know that needs to do that.
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Message 7 of 11
I'm trying to do the exact same thing and came across this post, I thought there would be an easier way to export a clash summary without the individual clashes....
Message 8 of 11
laura_asis
in reply to: robert.fern
I would also like to have this export
Message 9 of 11
TommyNYC
in reply to: laura_asis
Unfortunately (to the best of my knowledge) Revit is not compatible with clash reporting in the format we require to report, present and track for design teams.
I have seen it done very well -  but only using third party software's (such as iConstruct) to open up the NW info for appropriate export) combined with a bit of excel expertise on the other end.
Message 10 of 11
jmelodyJLDDY
I also think this type of report would be very useful.
Message 11 of 11
PatrickDavis20
While I do not know how to produce that report, there have been a couple of classes at Autodesk University that have shown ways to produce automated reports with the basic information you are wanting.
Years ago (10+) I know Turner Construction used to produce a clash report similar to what is seen below. (Image curtesy of BIMTrack).
Both options require programming expertise.
Patrick Davis
Twitter
LinkedIn
Blog
Rail Community
