Export of Navis sections into AutoCAD ?
Hi Team
is it possible to create 2D section in Navisworks Simulator and export to AutoCAD so that it can be further detailed?
filipefrancisco
No, in navisworks only images of a section.
But you can import in autoCAD the NWC files as external reference
Filipe Francisco
Comunidade Autodesk - Português - Colaborador
Autodesk Certified Instructor | AutoCAD Certified | Revit Architecture Certified | Autodesk Expert Elite
YOUTUBE | LINKEDIN
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou.
If the answer solved your problem, click Accept as Solution. This helps other users to quickly find an answer. And hit Like if you do.
Autodesk Community
hmunsell
have you tried printing to a Vector PDF? then the PDF could be brought into AutoCAD and converted.
Howard Munsell
filipefrancisco
@hmunsell did you try this solution that you said? it worked??
Filipe Francisco
YOUTUBE | LINKEDIN
Autodesk Community
hmunsell
Nope, Never had a need to 😊.  Just throwing it out there as an option to try since AutoCAD can import a Vector PDF and convert it to linework.
Howard Munsell
Is it? Can I import it? how? I tried all sort of things. I can´t find any NAVIS import
Why not I shall try, could work. I will try and report back
Thanks for the hint
