Export object data/properties from Revit file
Hello all,
I am using Revit to model Electrical trays/lighting/equipment for our project. and using Navisworks manage to merge other services like Duct/arch/civil.
We used to extract 3D AutoCad from Revit 3D for merging into Navis manage.
The problem is if we Append Direct Revit file in to mange then, the the color properties (which we have assigned and fixed in Revit filter) will not appear in mange but we can clearly see object properties with proper data in properties tab. (Refer : Below Snap-1).
If we extract AutoCad file from Revit and then we append in Navis manage we can maintain colors, which set by Revit filter but we are unable to see object properties. only some basic properties visible as per below snap.
Is there any way we can manage to get both (Color set by filter and properties of the object) in Navis manage?
any help on this much appreciated .
FKP
