Hi, thanks for your reply.
I found this weird problem that once a 3d model exported to fbx format by using navisworks, the texture (image) can only be displayed correctly by navisworks itself. other softwares like (Unity, blender) can't show the texture.
I attached two 3d model files with same content, this model only contain texture (image) and no color, no materials, one is original fbx file(Zombie.fbx), other is I opened the original fbx by navisworks and export to a new fbx file (Zombie-new.fbx)
The original fbx file was I copy the sample file from "Autodesk FBX converter 2013.3" software.
I tried Navisworks 2024,2023 even Navisworks 2015, but the problem was still happened.
Not sure how to export fbx with texture (image) using navisworks that can be correct load by other 3D softwares
Thanks.
David
