Element ID not available in Navis Work Manage 2024 via ACC
chester.daliwan
chester.daliwan
Good Day,
We are using the COORDINATION Tab when opening a Model via ACC.
When select an object and look for the Element ID, it is not available.
We are using element ID for clash adjustment just input into Revit.
Navis Works 2024
Revit 2024
Autodesk Construction Cloud
brett_parkerLUEP7
Thank you for posting on the forums.
We are not aware of this being related to ACC. If we open a Revit file in Navisworks (Not using the coordination tab) we do not see Element ID on geometry type items.
Can you confirm, if you open the same Revit file directly in Navisworks, do you see an Element ID for those items?
Regards
Brett Parker
Navisworks Product Manager
chester.daliwan
Hi Brett,
Please see video comparison opening via ACC and local drive (revit file) as you requested.
s.hamel
It's a bit complicated but you are comparing two quite different things, the cloud converted rvt file and the cloud converted nwc, which was originally a navisworks conversion of the rvt.
But in the end, the answer to where that element ID is for the rvt file is on the geometry item name in the selection tree, you just need to expand it out a bit as it is at the very end. This is not something Navisworks has any input on or control over.
Shayne Hamel
Manager, Principal Software Engineering
chester.daliwan
Thank you s.hamel
