Announcements
Edit and convert .nwd file to .stl
I have a file of Navisworks in .nwd format and I am looking for a way to edit it and convert it to .stl.
Preferably I could do the editing in AutoCAD of Inventor if possible.
Any suggestions on how this could be achieved?
dgorsman
You would have to export it to FBX first.  Note that with the multiple format changes (originating software => Navisworks, Navisworks => FBX, FBX => STL) you'll be losing a *lot* of precision.  It's not a suitable substitute for having the original files, which is somewhat the point of providing the NWD file - it's data rich and can be viewed in-context with other content, with less risk of the model being used where it shouldn't.
If this is being used as a reference, I would suggest referencing the NWD file directly in AutoCAD.  I don't think Inventor has that capability yet.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Thanks a lot.
How to convert FBX to STL? Do you mean to use Inventor?
dgorsman
Both AutoCAD and Inventor can read FBX files and export as STL.
