Distorted geometry when exporting IFC using iconstruct in Navisworks
Hi, I would like to know what causes the distorted geometry when exporting IFC using a plug-in in Navisworks.
I am trying to export 12D model to costx. But first, I need to incorporate some user defined data using navisworks and then export it in costx as IFC using a iconstruct smart ifc exporter.
the problem comes when opening the extracted IFC to COSTX, as it was appeared to be distorted.
or is there any other way to simplify the process. I need to put a user defined property/attribute inside the model and open it in COSTX.
Thank you.
gerard.hanns
any updates to this one? I am having the same issue.
thanks
