Distort graphic after saving in NWD
georg.grebenyuk
georg.grebenyuk
After open ReCap's model (or f.e. FBX file from Bentley ContextCapture) of terraria and industrial buildings in Navisworks - all parts of model looked like correctly, but after savind in nwd-file all models are distorts. We tried change parameters of import files in Settings of Navisworks - it hadn't influence on view.
Anybody have same problem? I can't solving it.
Below examples of problem - screenshots of object before saving in nwd and after it.
BEFORE
AFTER
I think - NWD file distort graphic, that was import from point cloud...
Best regards,
Egor Grebenyuk,
JSC "Roszheldorproject", BIM specialist (infrastructure)
georg.grebenyuk
Problem was solved 🙂
In Settings of Navisworks User must change some parameters below:
 Pic 1. Turn off compression of geometry in NWC file
 Pic 2. Turn off compression of geometry in NWD file
We used Bentley to create models of industrial building with photos (photogrammetry) and Bentley export geometry (Mesh) into FBX file. So - compression of geometry in NWD file [checkbox in Attribute: accuracy = 0.001] is critical parameter, because Mesh surfaces was simplified - and we saw Pictures as Post above.
Best regards,
Egor Grebenyuk,
