Hi All,
I'm trying to import a DGN file, but lots of elements was not converted.
Googling about this issue, I find that it is necessary to use the nwc export utility in Microstation(link ref 1).
But when I put the command mdl load nwexport12 microstation return MDL Loader: Could not load application nwexport12
I try to find the .ma file to refer in microstation but i couldn't find it, it's not in Navisworks Simulate 2016 instalation folder and in Navisworks 2016 64 bit Exporter Plug-ins
Could you help me to import the navisworks MDL library in microstation properly?
To export from DGN to NWC.
link ref 1: https://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/20...
Thank you
Solved by daniel.almeidaXZBC5. Go to Solution.
I'm sorry about the duplicity.
I found the solution here:
The important information is that the DGN exporter is only in the 32bit version.
Regards
Hi
Now that MicroStation CONNECT (64bit) is available and soon to be compulsory (V8i will be made obsolete this year), can we have a 64bit version of the Exporters please.
If this is possible, what time frame are we looking at ?
Thank you
Ian Lapper
Hi Autodesk
From 1st January 2021. All Bentley V8i (32bit) applications are no longer supported and users are forced to their new CONNECT version aka v10. As mentioned this tool doesn't work with CONNECT. With this in mind we really do need this converter.
can you update us when or if this is going to happen.
Thank you
Ian
HI its mid 2021. any updates on this please. We need the plugin to work with MicroStation CONNECT
Thank you
Ian
Sadly not.
Also no one from Autodesk has replied, I was wondering if this forum monitored by Autodesk.....?
Hi Dominic
i have tried the new CONNECT version of the NWC exporter. Sadly I fails to load. Can you outline what you did to make it work please.
IAn
hi Ian
nothing special. it works like the older one's.
maybe you have to uninstall the older exporter's, or all and then install only the version 2023.
dominik
