Clash Services Against Openings or Penetrations
Duvylove
Duvylove
Hi All,
In Navisworks, is it possible to clash against openings or penetrations as illustrated in the image below? If so, is it possible to export these results unto a spreadsheet like excel?
I look forward to hearing from you all
Thank you
Kind regards
Tomislav.Golubovic
What exactly do you need to know? The clearance? Or if its actually hitting the wall?
Duvylove
I want to know if it is possible to clash against an openings or penetrations. I need this cheat method for a fire stopping exercise i am currently working in which the clearance between the openings and services will also be useful
Duvylove
I do not have a "Builders Work Hole" model so I have to clash against voids which is very tricky hence I am open to suggestions
Tomislav.Golubovic
Well you won't be able to clash a hole because there's nothing to clash. You'll only be clashing with items that are physically touching one another. To check for clearance in a clash, you can change the settings in the Clash Test to "Clearance"
