Hi folks,
I want to be able to run an internal clash test in navisworks for a structural model. When I run the clash detective without any rules, it finds clashes that are not real. Such as a beam with a column.
For that I want to create a rule that ignores clashes with:
- structural framing & floors
- structural framing & structural columns
- structural framing & structural framing
- walls & structural columns
- walls & structural framing
- walls & floors
- floors & structural columns
However to create such a rule, there is no option in the rule editor such as, Specified Properties with Specified Values
How can I achieve this? Any ideas are appreciated.
Thanks in advance.
Solved by Nicola_Ianeselli. Go to Solution.
Hi @psynan,
there is an easy way to do that. Apply a custom parameter to each group and then you can say to ignore the elements with that parameter in the custom rule.
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
