Clash Detection setup
deckerrWUF2H
Observer Observer
deckerrWUF2H
Observer
Observer
So wanted to see if other have same issue or ideas how to setup clashes.  I am working on a building with 10 levels or so and on each level we separate the floor into 3 areas.   Area 1, Area 2, and Area 3.  When I run clashes lets say Level 3, I end up seeing clashes on other levels that I don't want to see.  Also if I am clashing Area 1 how do I only see clashes for that area and not area 1 and 2 as well.  Is there away to be able to do that.
rrogersRM
You can split the models/NWCs up by level or use search sets to only clash levels against levels. I typically clash all levels at once on most of my projects and mark any clash groups on levels I am not currently working on as "reviewed" and assign "Level 04" or "Future" to the clash group. Then in Navisworks 2026, you can simply filter those results out. The Clash Grouper also really helps for grouping clashes by floor.
The areas are a little more tricky since there's nothing in native Navisworks to do this but we use a 3rd party plug-in called Flypaper Sherlock to create areas within the NWF. Unfortunately, they were recently acquired by Procore, so I don't believe you can purchase a stand-alone license anymore.
Feel free to DM me if you'd like more help. I've been doing advanced Navisworks clash tests and search sets for at least 8 years now.
