clash detection between mass\generic model to other element
amir.aroesti
amir.aroesti
hi,
I try to do clash detection between elements with volume to other elements in the model.
see the example below.
ass you can see the whole wall is completely inside the mass and it doesn't clash with the surface of the mass.
what I'm trying to do is to create a mass  that demonstrates some areas in the model in order to clash between the mass and the element in the model.
Mohamed-Nassar
Hello @amir.aroesti
Can you share the clash test with me may i can help you.
any way you can create a clash test and assign this categories to the clash test whenever you can detect the clash between them.
Best Regards,,
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
