Announcements
Circle Display
bone14701
Circle Display
bone14701
Is there a setting to get circles/Arc's to display as circles/Arc's?
anton.gorbatch
You need to increase the Faceting Factor(at the very end of the help it says). Try increasing the value to 5-10 when exporting the file to Navisworks.
https://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/20...
bone14701
I'm not exporting the file. I'm directly loading the .dwg file into Navis. I'm assuming there is a setting in Navis that will smooth the circular objects.
bone14701
@anton.gorbatch found it. Thank!
korayyun
Can you explain the solution?
brett_parkerLUEP7
The faceting factor inside Navisworks can be found here;
Many of the files have their own faceting factor.
Regards
Brett Parker
Navisworks Product Manager
korayyun
thank you.
