Hello
Does anyone know how to change the orientation of the X and Y axis within Navisworks?
I want to rotate these axes so that, when moving an element, the Gizmo axes are aligned with the orientation of the building. I have attached some screenshots for your reference.
From reading other forum posts, it is my understanding that the X & Y axes are from your first model you append, however after lots of trial and error I can't seem to change the X and Y from the North and East global axis orientation. I am also trying to avoid rotating all appended models so that they are in the correct orientation relative to True North.
Any help would be much appreciated
Jack
Create a new NWF
append the first model
If X - Y is not the way you want
select the model in the Selection Tree
-> Right mouse menu -> File Units and transform
rotate 90 (or 270)
around 0 / 0 / 1 (which is the Z-axis)
Then this should be OK
Then append all other models
