Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Dear all,
On my workflow with client, I work with Navisworks Manage, I have made several clash test and export the viewpoints as a report. But my problem is, when I export to NWD file to open these viewpoints in Navisworks Freedom, I can't see the colors of viewpoints "green and red" colors as it is performed in Clash Detective.
Thank you for your collaboration,
Best regards,
The visual overrides are strictly for the Clash Detective. They aren't applied to the saved views, as it's more than just a simple color override.
In the few cases where it's not obvious what is clashing, I throw a redline on the saved viewpoint. That, along with the comment attached to the saved viewpoint is usually enough.
Indeed they are not showing.
With a lot of manual effort, you can select the clashing items manually, override their color to Orange or so and then update the viewpoint created by the clash detective.
Then these orange overrides, and the manual redlining may be in the NWD you create afterwards and is visible in Freedom.
