Can't import, open or append XML file in Navisworks
I'm having an issue when opening/appending a XML file in Navisworks Manage 2018.
whenever i attempt to do this i receive the error message "No plugin exists that will open XXX.xml"
Does anyone know how i can get around this or rectify this issue so I can open a xml file in navisworks please?
Kindest regards
Daniel
a_meteni
We don’t Open/Append XML files in Navisworks. Rather you’ll need to Import this XML file in its proper category (i.e. Viewpoints , search sets , Find items……)
Line 895,column 131
code 80004005
Error parsing
-7777638063858452838505678605191933163842542992751683869948127755189390911115368595456.0000000000 as float data type.
The attribute distance with value
failed to parse.
0
