Hi! I´m new in Navisworks Manager and I have problems with the conversion from Cadworx plant.
I need to convert with Navisworks from .dwg to .nwd but when I open the file in Navis I loose the properties of all the components, I can´t see the pipes properly.
Does anyone know why ?or... how I have to save the file in Cadworx?
-Navisworks manager version: 2016
-Cadworks plant version : 2015
Thanks a lot!
Solved by Patrick_Aps_9121. Go to Solution.
Thanks a lot Patrick_Aps_9121 for your answer !!
your advice was very helpful!!
I finally found another way to do it changing settings on Navisworks but I´ll save your advice just in case of having ptoblems again, it´s practical.
Monicavillar, to see CADWorx in Navisworks, you said you found an other way by changing some settings in Navisworks. Do you remember what they were? I really would appreciate. Thanks
Hi, ask to your CADWorx dealer for the CADWorx Object Enabler or you cand find it in your installation disc, install it using administrator rights, restart your machine, then using Navisworks Simulate / Manage, save it as NWD, it can be oppened with Navisworks Freedom!! even you can lik it with MS Access / Excel to view as many information as you want!.
for more information you can visit:
Best Regars,
miguel.estupinan@xsystemla.com
Hola, me podras pasar la configuracion que relizaste para resolver este problema por favor,
