Best practice when federating and appending ACC models into Navisworks
Ben_Finning
Ben_Finning
I'm wanting to know what is the best method to append linked models from Autodesk Construction Cloud. My employer has shown me to methods: Method #1: Opening the .nwf file from Autodesk Docs then refreshing the links from coordination folder. Method #2: Using coordination Plugin and appending the models from a coordination folder from ACC.
What are the pros and cons from these two approaches?
a_meteni
In Method #1: you’re using Navisworks desktop app to Open/Append NWF/NWC files that are stored on ACC Docs via Desktop connector. (Only NW subscription required)
In Method #2: you’ll use the Model Coordination module and publish the models toBIM Collaborate pro (pretty much Naviswors but on the cloud and will require additional subscription)
