Bentley Openplant Objects in Navisworks
As we all are know Bentley Autoplant Models we can pulled into Navisworks.
When we append it AutoPlant components are shows properties in Navisworks (i.e pipe size, spec etc).
Navisworks have AutoPlant Datatools as by defult. (attached snap)
If I try with OpenPlant models it works like as general dgn file which is not showing any OpenPlant properties, shows only as cell.
Is there any way to get those properties got through Datatools?
Anyone know how to set up datatools with MS access?
Thank you.
Rakesh Saka
MWH Global
sureshchotrani
Wellcome to the community:)
You will have to install the object enabler as described here.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Hi Suresh,
Thank you for reply.
I know this process which is work only for Bentley Autoplant (ACAD based) object not for Bentley OpenPlant (Microstation Based).
I want to make it works for Bentley OpenPlant models.
Rakesh.saka
