Auditing a Navisworks model for distant objects
lee.mullin
Alumni Alumni
lee.mullin
Do you get any of the following problems within Navisworks?
  • When you render your model through Presenter, only the background shows, or you seem to get holes or triangles missing from a render
  • When you navigate the model it looks like you have a section plane in front of you, as describedhere
  • Jerky performance when navigating
  • Model disappears when rotating around the model
  • When you zoom out the model disappears
  • Two faces seem to occupy the same space giving a jagged looking surface
Lee Mullin
Construction Technical Specialist
Autodesk Ltd.
lee.mullin
RobinsonG
Many issues with distant objects can be avoided by unchecking ( do not import) lines under Options --> File Readers --> Convert Lines.
My issue with CADPIPE files went away i.e. the files being processed by Navis 2012 Manage no longer "exploded" scattering debris out by Pluto.
"To see things in the seed, that is genius". Lao-Tzu
RobinsonG......you are the man!
Worked great. Thanks!
