Solved by Nicola_Ianeselli. Go to Solution.
Assuming I understand your question correctly, I would use Revit schedules to do perform this model check.
You can very fastly add a bounding box for each level and show everything inside this bounding box displaced in a schedule. This way you can add the parameter you want to check. Like bottom and/or top constraint. Or Level in general. This way you can check if the right objects are placed at the right level (read: bounding box).
Some information about bounding boxes you can find in this link.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Hi @pipapongo0909,
you can do everything you are asking in Revit.
Look at this. Model Checker.
http://www.biminteroperabilitytools.com/
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
Thanks for the response. This looks really promising, that gets a high position on my todo list.
Hi @pipapongo0909,
let me know how it goes.
I am at your disposal for any clarification.
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Hi @pipapongo0909,
as far as I know it only needs the first connection. I think it may just need to be activated, but it is free.
Yeah I work with Navisworks a lot. I use the Model Checker because you can use the Checker Configurator.
It's a lot easier.
Reach me out if you have any question
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
