2024 Update 2
2024 Update 2
Todd_Rogers
Mentor Mentor
Message 1 of 9
2024 Update 2
Todd_Rogers
It appears that the 2024.2 update has broke the Batch Utility. It opens, but when you click on Run Command, nothing ever happens.
Anyone else notice this?
Todd Rogers
Civil Administration
Replies (8)
Message 2 of 9
Tomislav.Golubovic
Tried running Navisworks as Administrator?
Message 3 of 9
Todd_Rogers
Was running fine until the update.
Todd Rogers
Message 4 of 9
brett_parkerLUEP7
Thanks for posting to the forums. I am unable to reproduce on my side. However, 2024 update 3 was released 31st October, are you experiencing the same issue in that update?
Regards
Brett Parker
Navisworks Product Manager
Message 5 of 9
Todd_Rogers
Yeah, I noticed that this morning. I will check and see if this fixes the issue.
Todd Rogers
Message 6 of 9
Todd_Rogers
Update 3 did not fix the issue.
Installed 2025, it worked. However, now the Civil 3D objects do not show. They show as proxy entities. I have installed/unistalled/installed the object enablers and still they show as proxy entities.
What is going on? I'm wasting lots of time fixing this software! Thank God I don't work for a reseller anymore!
Todd Rogers
Message 7 of 9
Tomislav.Golubovic
After you installed the OE, did you delete the .nwc of that file so it can be recreated?
Message 8 of 9
mpriestman
Hiya,
@Todd_Rogers, do your files contain Civil 3D OE objects? If so, then I suspect this is a known issue with 2025.2 and 2025.3 around loading DWG files. We have a fix internally and hope to release it soon. Hopefully this should fix your issue.
Sorry for the problems this has caused you.
Michael
Navisworks Principal Engineer
Autodesk Inc.
Message 9 of 9
Todd_Rogers
They do. And I have installed the OE 2 times.
Todd Rogers
