When adding a ViewControl in NavisWorks, the following error message is displayed:
2223854780
Community Visitor
Community Visitor
2223854780
Community Visitor
Community Visitor
Added a viewcontrol control via a dll file, but when dragging and dropping it onto a form in the toolbox, it says that the creation of the component "viewcontrol" failed with "System.IO.FileNotFoundException: Failed to load file or assembly Autodesk.Navisworks.Failed to load file or assembly Autodesk.Navisworks.
There should be no problem with the reference to the Autodesk.Navisworks.Api, as the following code runs successfully.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @2223854780 ,
Apologies for the delay in addressing your issue.
I recommend downloading the Navisworks SDK and running the Viewer samples located in "net\examples\Controls\Viewer". If the sample runs without any issues, you can compare the SDK sample code with your own code to identify any discrepancies. I tested the SDK sample, and it worked fine for me.
Navisworks SDK: https://aps.autodesk.com/developer/overview/navisworks
Additionally, when I ran the sample in Navisworks 2024, I encountered an error, but I was able to resolve it by following the steps outlined in the link below:
https://adndevblog.typepad.com/aec/2023/06/navisworks-2024-sdk-is-posted.html
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @2223854780 ,
Also, Please take a look at this below link
https://apidocs.co/apps/navisworks/2018/87317537-2911-4c08-b492-6496c82b3ed8.htm
Naveen Kumar T
