W key in Navisworks
W key in Navisworks
piero.urrutiaRA2LP
W key in Navisworks
piero.urrutiaRA2LP
Is there a way to override the W key to have the API do something else rather than show/hide the steering wheel?
I am using the KeyDown() function for InputPlugin but every time I use the W key, it does not perform the intended tasks, instead it shows/hides the steering wheel for navigation.
Any ideas?
Thanks!
lanneauolivier
try returning true at the end of KeyDown(), this stops Navisworks default behavior.
piero.urrutiaRA2LP
Thanks! It worked! However, when I press W, the function does not go through instead it shows/hides the steering wheel. In order to make it work, I have to first press other keys that have custom functions tied to them and then press W. Do you know what could be the issue here?
lanneauolivier
InputPlugin have the focus when le viewer has the focus to.
Clic on the viewer, then your W key should work properly.
This is quite annoying for key detection, you can still force the focus on the viewer with
Autodesk.Navisworks.Gui.Common.DockingView.ActiveView.Activate();
piero.urrutiaRA2LP
Thanks for the response! I do click on the viewer before pressing any keys. The only key that does not respond is the W key, the only way to make it work is to press other keys before pressing W. I think it might be because W triggers the SteeringWheel, but I cannot figure out how to solve it. It somewhat works as long as I press other keys before pressing W, but I don't know if there is something I can implement in order to avoid this from happening.
Thanks!
