troubleshooting naviswork TimeLiner connection to Primavera P6 via WebServices
p.dimascio
Observer
p.dimascio
Observer
Observer
Hi all,
i have a Primavera P6 (EPPM v.20.12) installed on-Premise, completely working with webServices running.
I'm trying to connect the Navisworks's TimeLiner just by adding the connection as simple as is.
I tryed to use the SSL port, the standard port, the webservices port, but none has worked.
The error while using the standard / SSL ports is:
"Connection interrupted by he host computer"
The error while using the WebServices port is:
"WSS header is missing from request. Can't do username token authentication"
There is also an anomaly: the errors above are notificated only after the first attempt, from the second attempt with the exact same parameters Naviskworks say:
"...Status code HTTP 404: NOT FOUND"
Obviously everything is fine when using file import with .CSV o .MPP, but i need to connect directly the timeliner.
Someone facing the same problem?
Thankyou very much.
Peter
Replies (0)
