To set Navisworks window size by aspect ratio
k-horiYJ27A
k-horiYJ27A
Hello everyone!
I am a beginner who has started learning NavisWorksApi.
I am currently looking into how to change the NavisWorks window size to 16:9 aspect ratio. (See attached image).
I am thinking that perhaps I can change the setting from ComAPI, but I don't know how...
Can anyone offer a solution?
Thanks!
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @k-horiYJ27A ,
No, it is not possible to modify these values using the .NET API or COM API.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
tetsuya_miwa
Use Win32 API setwindowpos.
You can get NavisWorks Main Window's handle by Autodesk.Navisworks.Api.Application.Gui.MainWindow.Handle.
https://learn.microsoft.com/en-us/windows/win32/api/winuser/nf-winuser-setwindowpos
k-horiYJ27A
Thank you very much.
Thank you also @tetsuya_miwa.
Perhaps it seems a bit too challenging for me now, so I will definitely try it when I have more experience!
