The possibility of Undo command modification in Navisworks as Revit for previous & forward commands with Drop down arrows
bandari.322
Observer
bandari.322
Observer
Observer
Good evening Autodesk team,
You are doing well in upgraded versions. Up to 2023 version of Navisworks,
the Undo command of Navisworks programming/code is not like Revit with Drop down arrows
for previous commands we can go back (Undo) and (Redo) for forward commands and work from where we require.
If is it possible to apply the program/code for Undo/Redo command in Navisworks as Revit,
because we can't save work/review status without loss  when using Undo command
as per present Navisworks versions(for all types of Navisworks might be apply).
So, Kindly could your software programming/Support team look in to this.
We hope that, this update might be upgraded in future versions.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @bandari.322 ,
I have logged Change Request number NW-59959 [ Improving Undo Commands in Navisworks: Revit-style Modifications for Previous and Forward Actions ] with our development team as this issue requires a modification to our software. Please make a note of this number for future reference.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
